Label Update
Brian Shannon
Label Update
Postby Brian Shannon » Wed, Mar 29 2006, 3:27PM
I downloaded the Label Update for Avery labels from eCabinet World onto my laptop. Then I unziped and put the .exe file on the memory stick, took it the the machine and when I try to open the file I get this message:
COPY FROM CHART
could not open registry to retrieve base path.
Any ideas?
Postby DanEpps » Wed, Mar 29 2006, 4:26PM
Brian
You are getting this when you try to execute the exe file, correct? Try copying it to the C: drive on the laptop and see if that helps.
Brian Shannon
Postby Brian Shannon » Wed, Mar 29 2006, 8:15PM
Thanks Dan, I'll try that. I usually print labels from the Router. Should I copy to c: on the laptop then memory stick to the router?
Paul Ford
Postby Paul Ford » Thu, Mar 30 2006, 1:51PM
Hi Brian,
I think what Dan is saying, you might need to copy and paste the .exe file from your memory stick to your controller and then try running the .exe program straight from the controller rather than the memory stick.
Hope this helps,
Paul.
Postby DanEpps » Thu, Mar 30 2006, 4:13PM
Ummmm, I'm not sure this will work. This update corrects a label alignment problem in the eCabinets label printing area.
Brian Shannon
Postby Brian Shannon » Thu, Mar 30 2006, 5:00PM
Nope,
It doesn't seem to work. Not a big deal. I use labels on a spool. I just wanted to print the info to regular paper then handwrite info on the part so I don't waste so many labels and also have to remove them on my small jobs. Thanks for the help guys!
Brian
Paul Ford
Postby Paul Ford » Thu, Mar 30 2006, 5:14PM
Sorry guys, i didnt realise this was a fix for the eCab's labels. Sorry I couldnt help you there Brian
Postby DanEpps » Thu, Mar 30 2006, 8:19PM
Sorry for the confusion. I changed the text on the download to read \"for eCabinet Systems only, not for CNC\".
