machine cutting too deep
Nemanja Vujkovic
Post by Nemanja Vujkovic »
CNC is cutting too deep on outline cuts. Dados and holes are fine it's just outline cuts.
Does anyone have a recomendation?
Thank you!
Joe Soto
Post by Joe Soto »
Nemanja, Check to see if you cut through depth has been changed somehow, also if you use the outline tool only for outlines, the tool length may be off.
Nemanja Vujkovic
sorry i could not answer earlyer
it seams that the bit started walking out of the tool holder due to hiting
thanks
