Pressure at the machine!!!
Each regulator at the machine has a plate with PSI value. The question is, is that maximum, minimum, or exact pressure for the regulator?
Hello Nemanja,
We typically recommend 90 to 100 psi at the main. If you are not using any aggregate tools then you can turn it up some and it should not affect the machine. You may want to check the small gauge that is marked for 58 psi for the tool release. This gauge reads 0 until the tool is released and then it jumps up to 58. If you turn the main up you may have to adjust this back down to 58 psi. If you have any questions or run into any problems, please call us here at Thermwood.
Jason McDaniel
Machine Support Group
