Hi
We are having a promblem with a (Error Code 3050 X axis out of bounds) which pops up while cutting it happens about 300mm from the end of the table, then the machine stops an we skip one line and it is right again. When we write the code there is no Error found, I have checked the table settings they appear to be right.
ERROR CODE
Re: ERROR CODE
Tim,Tim Wright wrote:Hi
What does the line you are skipping say?
Re: ERROR CODE
Tim,
If you would like you can attach the NC code that was generated by your machine, and tell me what line number gives you the error.
