rn 4.71
Jeff Norris
rn 4.71
why wont rolling nest interpolate a .196 hole with a .125 bit set to interoplolate up to .26?
Josh Meyer
Jeff,
As long as you have the .125\" tool set up to interpolate to a diameter larger than the hole, you shouldn't have any trouble selecting that tool. Verify that the diameter of the hole is .196 in eCabinets and also verify that the diameter of the .125\" diameter tool is in fact .125\" in the tool table for that specific tool number, F9, F2. Is it attempting to use a different tool or is it just giving you the error \"tool cannot be found for operation\"? If the problem remains after checking these couple of things, I will need to get some files from you to reproduce and troubleshoot the problem.
