What vacuum pressure should I be getting with my 15 HP Busch on a Model 40 w/ 5X8 table? What are other shops seeing?
Brian Shannon
Moderators: Jason Susnjara, Rich Kasten
The spoilboard that comes with the machine is 32 lb density and the wasteboard is 48 lb density. If you are not machining 5 x 10 sheets, you can use a 4 x 8 wasteboard. I belive that we have to machine both the spoilboards and the wasteboards here to the correct dimensions because we order it oversize. Hope this helps.
Return to Thermwood 3-Axis Machinery
