one more problem
one more problem
I am doing an upper corner cabinet with shelves, but when i nest it, the line bore is not there. An error "Could not find tool to work pocket operation..."
- Attachments
- ControlNest5-46.zip
- (53.35 KiB) Downloaded 277 times
- cornerUpper.zip
- (319.36 KiB) Downloaded 291 times
Re: one more problem
All of your shelf holes measure .1874 in diameter and you do not have a tool set up in your operations this size. The closest I found was the .1969(5mm). Once it does not find a tool in the operations, it then checks the pocket tool. Your pocket tool measures .406 so this will definitely not work. This is just a work around, but if these are suppose to be 5mm holes you can change the diameter in your tool management for the 5mm tool to .1874 for this job and then change it back afterwards but you should really correct the cabinet. In Ecabinets, check your settings to see if you have "round to the nearest mm" checked. Hope this helps.
Thank you Daniel, i feel so stupid!!! The holes are spouse to be 5mm, i do not know how they got to .1874. I went to eCabs and changed the diameter of the holes there.
