One Part, More than one Edgebanding, Slab Doors too
David Hall
Postby David Hall » Fri, Jan 23 2009, 6:22PM
For commercial work, we frequently edgeband the bottom edge of wall cabinets ends with one color and the front edge with a different color that matches the doors.
The current implemenation of edgebanding on labels prints only one of the EB names.
Can we get all the EB names listed? Please.
Even "EB: name 1, name 2" would be a big help. We can figure out which one goes where, and in which order they should be applied.
But if you're feeling industrious a solid line on the picture for EB 1 and a dashed line for EB 2 would be cool. We've never had more than 2 different Edgebandings per part. I think we've had as many as 4 different edgebandings per job.
Also, Slab doors with edgebanding are listed on the labels with "EB: None", and no picture.
Dave
David Hall
Hall's Edge Inc.
eCabinets Machining Services
http://www.HallsEdge.com
Jeremy Schiffer
Re: One Part, More than one Edgebanding, Slab Doors too
Postby Jeremy Schiffer » Sat, Jan 24 2009, 1:11AM
You read my mind David. We're just dealing with a job like that (several actually) that would greatly benefit from being able to display more than one type of edgebanding. I like the idea of a dashed line to differentiate. Count me in on this one.
Neville Bastian
Postby Neville Bastian » Sun, Jan 25 2009, 2:54AM
I would also put my hand up for different edge colours. On commercial work this is fairly common. Could not the edges have different printed colours if using a colour printer. It may not be the exact colour but it meets the new thinking of Ken where you shouldn't need to read the colour but visually see it. This would be handy for shops who employ people who can't read. Most of my staff cant read, I put on the plans glass window and out comes a standard door. Now I resort to yellow highlighting pen.
Regards
Neville
Neville Australia
Larry Epplin
Postby Larry Epplin » Tue, Jan 27 2009, 9:48AM
We'll plan for implementing a solution for this delimma. Thank you for the input.
Zach Froble
Postby Zach Froble » Wed, Jan 28 2009, 10:54PM
I am cutting a job right now with slab doors and the labels have no picture.
I would also like to see different EB materials on the same label.
Zach
Lyndan Designs
Machining and CAD Services
David Hall
Postby David Hall » Fri, Jan 30 2009, 4:07PM
Hi Larry,
I need to add one more... Face frame parts with edgebanding currently get the same silent treatment from label printing as slab doors.
i.e. no picture and "EB: none"
Dave
David Hall
Hall's Edge Inc.
Larry Epplin
Postby Larry Epplin » Fri, Jan 30 2009, 4:26PM
Ok. We'll get that fixed as well. Just a note. The Slab Door and Face Frame information will need to be addressed in eCabinet Systems. Having the multiple names listed can be done in a Control Nesting update. Thanks again for the input!
Neville Bastian
Postby Neville Bastian » Fri, Jan 30 2009, 6:37PM
Hi Larry,
The Ecabinet programmers seem to be focusing on bigger and better top secret projects within Ecabinets. Bribes to supply pizzas will not loosen those lips on what version 6 has to offer. The edging issue may take awhile to happen due to priorities, As a interim solution could we not be able to manually change edging at the controller. In my case where some of my parts are white edged and some are the same colour as the door I could select all the parts with a check box and change the edging wording to door colour on those parts. I can't remember how drawer parts are handled but if I could add edges with the colour required that would be handy. At the moment ecabinets won't allow you to assign edging information to drawer parts.
With the right interface I could get the result of what I wanted within a few minutes.
I know a few are asking for colour highlight on their labels to show different colours. I use a Zebra label printer which only prints black. Could this be discussed with the programmers as I would guess many others would use a monochrome printer. Maybe different types on lines could be used. Single thick black line for white for example. Dash space dash for colour 1, dash dot dash for colour 2 etc. These could be still be printed in different colours but with added bonus that all users benefit.
Nev
Neville Australia
