MELAMINE AND RAMPING
Zach Froble
Postby Zach Froble » Thu, Sep 22 2005, 11:58AM
I have been experiencing some problems when cutting melamine panels. I am using a 1/2\" compressing spiral and while the cutter is ramping the up-cut on the bit is chipping the melamine.
I was wondering what everyone else was doing about this. I thought about not ramping and just plunging into the cut, could someone tell me what the setting should be in rolling nest to stop the ramping or any other suggestions that help.
David Hall
Postby David Hall » Thu, Sep 22 2005, 1:31PM
Don't stop ramping, just set your \"outline pre-ramp depth\" equal to the upcut portion of your compression bit. You may want to do the same thing for your \"Dado/route pre-ramp depth\"
These are on the settings page in rolling Nest.
Dave
David Hall
Hall's Edge Inc.
eCabinets Machining Services
http://www.HallsEdge.com
Jason Susnjara
Postby Jason Susnjara » Thu, Sep 22 2005, 1:35PM
Hi Zach,
David is correct. One question though, what compression bit are you using? Are you using the mortise and tenon compression from Vortex? What is the length of the up spiral?
thanks,
Zach Froble
Postby Zach Froble » Fri, Sep 23 2005, 10:44AM
I am not sure what brand of compression bit I am using at the moment, but I don't think its a mortise and tenon compression. Someone else did tell me to try those, what is the difference?
The upcut on the bit I am using presently is 1/2\", so should I change the preramp depth to 1/2\" or is that to much.
Thanks again for the help!
Jason Susnjara
Postby Jason Susnjara » Fri, Sep 23 2005, 11:09AM
The difference is the upcut. On the mortise and tenon compression sprial you will have a .25 up sprial that will allow you to also cut dados. You will either need to change your outline pre-ramp depth or change the ramp in so that it is very short but not a direct plunge.
Users browsing this forum: No registered users and 7 guests
