MDF Doors?
MarcoKnjaschewitsch
MDF Doors?
Ok try this here...so i made an MDF door off the machine using regular spiral bits. But when finished i am having a problem with a Pitted Look. The outter cut edges also have a problem as they are rough (this all after sanding still) What do people do to seal there MDF or Fill these pits first before Painting or is there a paint that would best work with MDF. OR am i using the wrong Grade of MDF to make doors!
FredHirsch
Re: MDF Doors?
The grade of MDF makes a big difference. In our area plumb creek or the canadian stuff is pretty good. Also we prime with Sherwin Williams Millwork Primer. Do 2 coats. This stuff is just like drywall paste. NOTE: we don't sand anything until after primer coats. Then we paint with ML Campbell Polystar paints.
Fred
Fred
Fred Hirsch
- Brian Shannon
Re: MDF Doors?
Try watering down some Tightbond 2 Glue and brushing on the new(cut) surfaces.
- Damon Nabors
Re: MDF Doors?
as others have stated, the MDF grade makes a big difference and you might adjust your step over. A smaller step over will take a little longer but will produce a better end result. I am assuming you are using the profile modeler.
Damon Nabors
Nick M Singer
Re: MDF Doors?
We spray all the moulded profiles with an automotive 2K spray filler first.
