I downloaded the Label Update for Avery labels from eCabinet World onto my laptop. Then I unziped and put the .exe file on the memory stick, took it the the machine and when I try to open the file I get this message:
Hi Brian,
I think what Dan is saying, you might need to copy and paste the .exe file from your memory stick to your controller and then try running the .exe program straight from the controller rather than the memory stick.
Hope this helps,
Paul.
It doesn't seem to work. Not a big deal. I use labels on a spool. I just wanted to print the info to regular paper then handwrite info on the part so I don't waste so many labels and also have to remove them on my small jobs. Thanks for the help guys!
