hi all, i just purchased the italian renaissance credenza on cd
and I cant view the darn thing, am i not doing somthing right i tried every thing i can think of with no results, i was wondering if anyone else is having difficulty.
thanks
mark
faulty design disk
- Company Name: mark cherry cabinets
- Company Name: Thermwood
The CD contains an EXE file, which you need to run.
If you run this EXE on an eCabinets pc, it will install the eCabinets files.
If you run this EXE on a Thermwood machine, it will install all the rental programs, etc.
Try the following;
START>RUN>Browse
Select the .exe file located on the cd.
Select OK
It should now start the installation process. After installation, you can open your eCabinets software and open it under 'cabinets'.
If you cannot select/see the EXE file in the above steps, then the cd may be bad or scratched. I can send you out a new one....no need to send it back to us.
Just let us know! Thanks!
Try the following;
START>RUN>Browse
Select OK
Thanks Kerry and Jody
your advice was very helpfull, but the disk is not working, my dvd drive is working fine , it plays all I put into it, so I assume the disk must be faulty I tried both proceedures with negative results,
so Jody if you guys can send me a new disk that would make this old cabinet makers day.
thanks Mark
thanks Mark
