Display Cost/ Price
Display Cost/ Price
Postby Kerry Fullington » Tue, May 22 2007, 4:04PM
I just noticed that using Version 5.1 build 3 under the View Menu there is no selection to \"View Cost/ Price\".
How do we get the Dynamic Cost Display to work?
Peter Walsh
Postby Peter Walsh » Tue, May 22 2007, 4:12PM
Kerry,
Under \"Settings and Preferences\" click on \"define costs\". Bottom of the panel. This what you're looking for?
regards,
Postby Kerry Fullington » Tue, May 22 2007, 4:32PM
No Peter,
In the previous versions when you dropped the View menu there was a selection to \"View Cost/Price\" that would display the Dynamic pricing at the bottom of the screen if you selected yes to Dynamic Cost Display in Preferences.
Postby DanEpps » Tue, May 22 2007, 6:51PM
I seem to remember Larry discussing removing the dynamic cost feature because it was a huge memory/performance hit.
Postby Kerry Fullington » Tue, May 22 2007, 7:11PM
Thanks Dan,
I see they have a drop down menu on the Create Cost Sheet Icon to get the numbers.
I will miss the Dynamic Cost Display. I used it to get immediate feedback on how different things affected the cost.
Donald Walls
Postby Donald Walls » Sat, Jun 02 2007, 5:15PM
It has been a while since I used the program and I am getting things set up again. Am I reading this correctly, that we will not be able to see the cost at the bottom of the screen anymore??
Donald Walls
Michael Yeargain
Postby Michael Yeargain » Sun, Jun 03 2007, 2:36PM
It appears that way Donald.
And, I agree with Kerry; I will miss this display as well. Unless the programers will wiggle their noses once more to incorporate the best of both worlds.
Windows 7 Pro/10 Pro 64 bit
NVIDIA GeForce GT 220 1GB
Joseph Fusco
Postby Joseph Fusco » Sun, Jun 03 2007, 3:36PM
I'd like to see that \"feature\" turned back on as well.
Bob Stern
Postby Bob Stern » Sun, Jul 15 2007, 5:55PM
At least they should take out the check boxes in the preferences.
Ive been clicking on them all day trying to get it to work!
Jeremy Schiffer
Postby Jeremy Schiffer » Mon, Jul 16 2007, 12:04PM
I'm the odd man here... I like it this way because now it doesn't recalculate everytime I do something, which has always frustrated me.
Hm, maybe an option in the prefs to have it be one way or the other?
Postby Kerry Fullington » Mon, Jul 16 2007, 12:38PM
Jeremy,
It is still re-calculating every time you make a change, you just can't see it now. The old way did allow you to turn it on and off in Preferences.
Al Navas
Postby Al Navas » Mon, Jul 16 2007, 12:57PM
DanEpps wrote:...I seem to remember Larry discussing removing the dynamic cost feature because it was a huge memory/performance hit.
Kerry Fullington wrote:...It is still re-calculating every time you make a change, you just can't see it now. The old way did allow you to turn it on and off in Preferences...
These two don't jive. If the dynamic price/cost was removed due to its effect on performance, but the program still IS doing it in the background, then it is a simple matter of displaying. Is it the "displaying" part that will give performance such a bad hit?
I would have thought that updating the cost/price data base in the background would cause the biggest hit on performance. BUT it could be that it is the same data base that keeps track of all the pieces and components of the cabinets; in this case, yes, everything is being changed dynamically every time one makes a change. But I also am NOT a systems guy - I am only a user.
What would be my preference? Make it an option to have it calculated or not (IF it does not cause a deterioration on performance, AND if possible to do so). And make it another option to display or not.
Al
Postby DanEpps » Mon, Jul 16 2007, 3:14PM
I'm not so sure costs are recalculated with every change. If you pick one of the options on the cost sheet dropdown menu it calculates costs before displaying the report.
One thing is strange though. When I go into Settings/Preferences and click the Define Costs button, it takes a full 10 seconds for the dialog to be displayed. Other buttons (Define Stock Materials, Define Standard Dimensions) are instantaneous.
Larry Epplin
Postby Larry Epplin » Mon, Jul 16 2007, 3:42PM
The Dynamic Cost display feature is being phased out. We unfortunately forgot to remove the radio buttons in Dynamic Markups dialog. Sorry for the confusion.
Postby DanEpps » Mon, Jul 16 2007, 3:58PM
What about the long time it takes after clicking the Define Costs button...is it just me?
Users browsing this forum: Exabot [Bot] and 19 guests
