pictures or drawings of cabinets for assemblers
Neal Reeves
Post by Neal Reeves »
I do not have a cnc router. I have table saws, radial arm saws, drill presses, and the like. My cutlists are working out fine for my cut man; however, my assembler needs a picture of the cabinet he ( or she) is building. Do I have to print off each cabinet through the line drawing editor, or is there a better, easier way. It would be nice to have a cut list and a drawing for each cabinet on the same sheet of paper. Is this possible?
Also, while I'm asking for the moon, in the drawings I am asking for, is there any way of getting measurements listed about each piece that will have dados as to where the dados are supposed to be located without manually pulling the measurements from the line drawing editor?
Pushing my luck,
Neal
Neal Reeves
Country Cabinets, Inc.
Bonifay, FL
Michael Yeargain
Post by Michael Yeargain »
Neal,
At this time, unfortunately there is not a way to get this without takeing each cabinet into the LDE. You can take all the cabinets in the LDE from detail room by selecting all the cabinets (S,S,C) short cut. And going into the LDE. When you get there you will have to orient every one to an elevation position and pull measurments.
You will also have to take the manual measurements for the dados as well.
32Gigs DDR4
NVIDIA GeForce GTX 960 4GB
Corsair RM650
Roger Kirkpatrick
Company Name: The WoodCrafting Company
Post by Roger Kirkpatrick »
Neal,
My workaround for this is that I do it manually.
I print out a picture of each cabinet then manually dimension the face frame, mark where the hinges go, finished end and spec out the slide.
I out source the cabinet boxes so my guys don't need to cut them.
If you semi-standardize like face frame is always 1\" larger than the box you should be able to work out a system and train your people to build from your print outs with just face frame measurements and just a few notes.
Not the best solution but that is what I came up with.
The WoodCrafter
Michael Yeargain
Here's an idea to help you understand a little about the software.
32Gigs DDR4
Corsair RM650
Michael Yeargain
Here you can see I copied and pasted from a text document the information of our imaginary friends...
32Gigs DDR4
Corsair RM650
Dennis Englert
Post by Dennis Englert »
Great tip on pasting the info in.
You can also copy and paste the info from the Cut List. One small piece of info is that you must be in the NOTE mode prior to pasting the info. The text from the document file or spreadsheet file will take on the properties that are set for the text, i.e., color, size, font, etc.
Another concept that I think is worth considering. Since most cabinet's are generally alike, I would create a line drawing for a cabinet. Then save the line drawing as a job, so that the drawings for that particular cabinet type can be accessed again w/o having to do all the LDE work again.
Michael Yeargain
Dennis,
When I do major kitchens, and just as I have that kitchen the way the customer likes it. I save it as a CustomerNameLDE. Then I delete all the cabinets in the room. and save it again.
I can use the LDE, quickly adding elevations by selecting a wall from the custom lay out view, and pasteing it into a new page, and it doesn't slow down my computer at all!
32Gigs DDR4
Corsair RM650
Jeremy Schiffer
Post by Jeremy Schiffer »
It's not usually necessary to use the LDE to print dado information. The easiest way I've found to get dado information is to nest the job and then click on the parts with dadoes on them. The measurements are already worked out and shown, all you have to do is click print.
CS-41 4x8
CS-45 5x12
