Poor Render Quality
Poor Render Quality
Postby Kerry Fullington » Sun, Oct 21 2007, 3:02PM
I am working on some moldings for pediments and even though everything is created in eCabinets, the segments show in the rendered views. Imported curved or turned items also render poorly. This wasn't the case in version 4. What has changed?
Todd Miller
Postby Todd Miller » Mon, Oct 22 2007, 12:26PM
Kerry,
I am not aware of any changes to our rendering functions. Try turning up the level of detail under \"settings/preferences\". But I am not telling you anything you already know. I will check with our programmers on this one.
Postby Kerry Fullington » Mon, Oct 22 2007, 12:38PM
Todd,
It seems like eCabinets used to create more segments to make a smoother render when you model something.
I also noticed that when I save geometry for a tool that I have created using a spline, When I open that geometry again the spline is now segmented lines and can't be used .
Todd Miller
Postby Todd Miller » Mon, Oct 22 2007, 1:55PM
Kerry,
The programmers say that there may have been some adjustments to the tesselation factors to help with performance. Also, we will look into a means of offering this adjustment to the user in the future.
Postby Kerry Fullington » Mon, Oct 22 2007, 2:06PM
Thanks Todd,
I can turn the curved moldings into display parts for rendered views. This will accomplish what I want for now. I would like to be able to toggle to get better quality in rendered views.
Joe Dusel
Postby Joe Dusel » Mon, Oct 22 2007, 2:10PM
Kerry,
I'm surprised that you didn't realize that this was probably a problem with the \"tesselation factors\". That was the first thing that came to my mind. 8)
We need to be able to adjust the darn \"tesselation factors\" even if we are clueless about them.
Paul Huff
Postby Paul Huff » Mon, Oct 22 2007, 7:00PM
I like the bends you put into this Kerry. Nice work!
By the way tesselation factors control the number of lines in a 3D model. More lines use more memory and computer resourses but produce the smoothest look. I think programmers try to find a balance between performance and the final appearance.
Postby Kerry Fullington » Mon, Oct 22 2007, 7:23PM
Joe,
I thought it was the tessellation factors all along but I didn't want to say anything.
Paul,
That isn't the correct curve for the piece yet. I was trying out the tool to see how it is going to mate with the straight moldings. I still have a little problem. I have already created eight tools to model this piece and still have at least three more plus some carvings.
I hope the programmers realize that as woodworkers we should never sacrifice quality for performance or profit. :wink:
Michael Yeargain
Postby Michael Yeargain » Mon, Oct 22 2007, 8:55PM
Contrary to the most obscured belief regarding the tessellation factors there is a reality that needs to be addressed here. The scientific community dating back for years now it has been sporadically referring to this as the redundancy of chiliad.
This is an overbearing controversy compared to the never ending debate concerning the vectorization module. In fact it was quoted by a major leader in the scientific community, \"The graphical matrix is getting' a junk value in the display parts translation vector\"
Regardless of the outcome there is hope. Thermwood
Thanks for reading. :P
Windows 7 Pro/10 Pro 64 bit
NVIDIA GeForce GT 220 1GB
Joe Dusel
Postby Joe Dusel » Mon, Oct 22 2007, 9:57PM
Thank you so much Michael for clarifying that. 8) It's like I always tell people, you don't need to be a rocket scientist to use eCabs. I have no problems and I only have a BS in engineering.
Postby Rick Palechuk » Tue, Oct 23 2007, 12:41AM
It looks to me like you also hold a BS in something Michael. :wink:
Postby DanEpps » Tue, Oct 23 2007, 5:52AM
Hey Rick...I think Mike confused tessellation with tesla and got zapped :lol:
Michael Yeargain
Postby Michael Yeargain » Tue, Oct 23 2007, 6:12AM
I hold a BS in my home and sometimes on the net. But that is only acceptable if the people have accepted the credidation from my former school of HK.
It could have been the zap from a telsa but I was clearly out of my mind when I quoted the scientific leader; Scotty from the USS enterprise. There is merit.
Here is a quote from Larry Epplin refferencing this as well.
I did find the problem though. It has to do with the graphical matrix getting a junk value in the display objects translation vector. If an object gets loaded that does not have a pre-existing matrix (such as a cube which is generated on the fly) the problem occurs. This is why ... They have a pre-existing matrix.
You see. I am not crazy! :roll:
Postby DanEpps » Tue, Oct 23 2007, 6:25AM
That doesn't prove you're not crazy...just that you and Larry are playing in the same sandbox :wink:
The attached shows how easy it is to hit the tesla switch when one means to hit the tessellation switch.
Toggle Switches.jpg (19.75 KiB) Viewed 3431 times
Postby Kerry Fullington » Tue, Oct 23 2007, 6:44AM
While in high school, one of my science classes built a Tesla Coil. They did a demonstration on stage at school once but couldn't play with the coil much because at that time (late 60's) most of the houses still received their television signal via antennae and the arc from the coil gave off enough RF signal to destroy reception for blocks around the school. Science is great until it causes someone to miss \"As the World Turns\".
Users browsing this forum: No registered users and 18 guests
