inset door bead
inset door bead
New to the software, can you do an inset molding on face frames for inset doors? and if so how?
that is good to hear, I might be new but I am learning fast, I used CV for 6 years and was very proficient in it, I use to build thousands of mantels per year and had CV set up to do amazing things with my designs. China has consumed the mantel business in north america, so I am doing mostly kitchens now and not locked into CV and all there upgrade charges, I have also fininshed 3 days of training at CNC Automation. Doing it in the part editor does sound very time consuming if you are talking about a whole kitchen. I was thinking of designing a door that has the bead on it for renderings.
- George Davidson
Hi Dan
This is the way I do it for rendering
I have the frames set up all the time(I can resizes them anytime any size)
Take everything off just keep the face frame_3/8\"w and keep depth at 24\"
- Shot2.jpg (133.36 KiB) Viewed 3936 times
- Beaded Cabinet D.jpg (86.36 KiB) Viewed 3936 times
- B.jpg (155.55 KiB) Viewed 3936 times
- George Davidson
- Company Name: NCB Inc.
Dan,
I know some shops actually cut the bead on the face frame, some shops add a beaded molding. I do a combination to avoid haunch cuts.
Are you looking for the quickest way to graphically represent the bead? If so, take the rails and stiles into the part editor and run a simple radius tool along the edge, making sure to create a path to start/stop where the rails intersect the stiles.
Click here to read a post from a year ago covering this topic/process.
Mike
Mike
Another way to show the bead as a molding and have it show up on the cut list is to take your seed cabinet to the face frame editor open construction settings, set add mid rail inset to negitive .375 left and right for 3/8 bead. On page 2 set the add mid stile and rail to .375 width, I change the material to one of a slightly different color fo it to show up better,hit ok. On your cabinet select an opening, add a mid stile, select the opening on the left of it and change the opening width to 0, add another, select the opening on the right of it set it to 0. Do the same to the mid rails. Repeat for any other openings. In the door editor set up whatever inset and gaps you like. This will give you a square edge but if you need to show a closeup of the molding you can take it to the part editor to shape and/or miter it. Save it as a new seed everything will resize.
Users browsing this forum: No registered users and 47 guests
