Partitions as intermediate gables
David Kopriva
Postby David Kopriva » Mon, Apr 14 2008, 1:45PM
Hi All
I am trying to use the insert parition as an intemediate gable. I deleted the deck but this does not allow me to bring the partition to the floor for a counter support. How do I accomplish this? Any takers? :?:
Re: Partitions as intermediate gables
Postby DanEpps » Mon, Apr 14 2008, 1:51PM
A partition must have a deck and top to connect to so, when you remove the deck, the partition is removed also.
You can add a display panel of the appripriate size to achieve the same result without the need for having a deck for it to connect to. Of course this method will allow only butt joinery unless you manually create dadoes/tenons in the Part Editor.
Another thing you can do is create a very thin (.001) material and make the deck from that material. Then you can connect the partition and use whatever joinery you wish.
David Kopriva
Postby David Kopriva » Mon, Apr 14 2008, 2:16PM
Thanks Dan
I tried this and it works. Then I removed the deck and guess what, the partitions remained in the cabinet. I suspect it will load in the cut list as well. :shock:
Dennis Englert
Postby Dennis Englert » Tue, Apr 15 2008, 11:34AM
To use a partition as a gable,
1. Remove the deck
2. Next determine the toe kick construction.
a. Method 1
1. Set the toe kick height and inset to 0
2. Install the partition. The partition will go to the floor.
b. Method 2
1. Set the height and inset of the toe kick to the desired height and inset.
2. Install the partition with a negative bottom inset that matches the toe kick height.
The partition (gable) will extend by the negative value towards the floor.
3. Install shelves to replicate the deck.
Users browsing this forum: Clint Buechlein and 16 guests
