I know that it is impossible to add applied ends to corner cabinets but I am wondering if anyone has the magic formula to figure out how to size the cabinet so that the parts are sized correctly to take into consideration the applied end. Hopefully that made sense.
here is an example...
Right now the cabinet is square but if I attach an applied end to the right side (as viewed from above), it is no longer square. if I resize the cabinet 3/4" smaller to take into consideration the thickness of the applied end, the cabinet will be square when finished but I believe the size of the parts eCabs calculate will not be correct, specifically the side, back, top and bottom parts will be incorrect. And the face frame part dimensions will be incorrect as well.
If anyone has any ideas, I would love to hear them.
Bob Magnuson
corner cabinets and applied ends
Re: corner cabinets and applied ends
Bob,
I had to use insets and replace the end with a display panel with part editor cuts.
- inset.zip
- (153.12 KiB) Downloaded 285 times
Hi BOB
I am not sure if this will help you
I have done 2 like this one with the panel on and one with the panel off![Toast :beer:](./images/smilies/pictobeersmall.gif)
The cabinet done is 36" x 36" Sq
- A.jpg (55.8 KiB) Viewed 3472 times
- D.jpg (59.26 KiB) Viewed 3470 times
- E.jpg (64.61 KiB) Viewed 3471 times
Last edited by George Davidson on Sun, May 11 2008, 2:16PM, edited 1 time in total.
Here is the corner cabinet in a Zip File
- Side Panel.jpg (30.13 KiB) Viewed 3463 times
- Corner Cabinet.zip
- (389.66 KiB) Downloaded 262 times
