Maple Mantel
Postby DanEpps » Sat, Nov 11 2006, 8:21AM
You are trying to open a job instead of an assembly.
Joe Foggia
Postby Joe Foggia » Sun, Nov 12 2006, 8:44PM
Thanks again gentlemen for the help. I moved it into a folder I named Standard. I didn't find one in /assemblies. I got it to pop up but then I had a problem in that it opend a material list that I needed to do something with but I couldn't figure out what. Trying to cancel the mat. list just canceled the drawing. So the question is what do I do with the mat. list? Joe
Re:
Postby DanEpps » Sun, Nov 12 2006, 9:07PM
DanEpps wrote:Craig
Extract the assembly to one of your folders in "Assemblies" then you can load it into the cabinet/assembly editor as you would any other assembly.
You will have to add the materials used in the assembly when you open it or substitute different materials for them.
When you open a cabinet or assembly that uses materials that you do not have defined, you have to add or substitute a suitable material for them.
Joe Foggia
Postby Joe Foggia » Sun, Nov 12 2006, 11:24PM
OK, it sounds like I just need to follow standard procedure and I will try that. Thanks again. Joe
Gary Puckett
Company Name: The Woodworkery
Re: Maple Mantel
Postby Gary Puckett » Mon, May 19 2008, 1:59PM
Hi I am new to e cabinets and would like to know how to see the maple mantel
Re: Maple Mantel
Postby George Davidson » Mon, May 19 2008, 7:36PM
Maple Mantel
Mantel Maple 10-24-06 (2).jpg (46.33 KiB) Viewed 2692 times
Mantel Maple 10-24-06 (1).jpg (79.39 KiB) Viewed 2692 times
Mantel Maple 10-24-06.jpg (47.16 KiB) Viewed 2691 times
John J. Desmond
Company Name: Wood Designs Unlimited
Re: Maple Mantel
Postby John J. Desmond » Tue, May 20 2008, 8:49PM
To anyone,
Why is it that I am not seeing this maple mantel? I can't even see a link. I have noticed on some posts this happens. Does it have something to do with computers? Am I missing something here?
John J. Desmond
Re: Maple Mantel
Postby John J. Desmond » Tue, May 20 2008, 8:51PM
Forget last post. I found it at the end of page 2. Is there a reason why I was unable to see it on George's first post?
Re: Maple Mantel
Postby Kerry Fullington » Wed, May 21 2008, 6:43AM
John,
Every forum member is only allotted X amount of server space for attachments. To be able to upload attachments on new posts we must go back to old posts and delete the attachment to open up space. This leaves many of the old posts without their original picture uploads.
George just uploaded the pictures again for you to see is why they re-appeared.
Return to “Customer Images”
