Constraint manager
Gary Urlacher
Constraint manager
Postby Gary Urlacher » Mon, Jul 21 2008, 8:32AM
Is there a way to constrain an object to the center of a panel?
I was designing some dowel construction cabinets and it seems I can only constrain these
to the edges of a panel. It would be nice to be able to have other constraint options such as
center of the panel and even the ability to constrain in portions such as 1/3 cabinet height etc
for fixed shelves etc.
Is this something that will be considered in the future?
an option for dowel construction would be great as well.
Gary Urlacher
FredHirsch
Re: Constraint manager
Postby FredHirsch » Mon, Jul 21 2008, 9:32PM
Gary,
I may not understand your request, but you can do this now. Put your dimension on you node, then edit the dimension but instead of 2" or whatever, put in there w/2. This will give you 1/2 panel dimension. You could also do some other math such as h/2+3 if you needed a hole half way up a side panel but wanted to account for a 3" kick (or would that be -3"?).
Fred
Fred Hirsch
Gary Urlacher
Postby Gary Urlacher » Tue, Jul 22 2008, 12:54AM
Thanks for the help Fred, That is just what I was looking for.
I will give it a try.
jerry johnson
Postby jerry johnson » Tue, Jul 22 2008, 11:50AM
THANKS, FRED! 8)
Users browsing this forum: No registered users and 20 guests
