Hello everyone,
I am having a problem measuring a tool.
After I select the tools I want to measure, and the tool is brought above the sensor, instead of the tool being lowered slowly, the tool is raised slowly until it cannot go any higher in which case I get an error 3052 Z axis is out of bounds.
I tried re-measuring a tool that had worked before this happened and it is also doing the same thing now.
Is there a way to fix this?
Thank You,
Andrew
Tool Measuring Problem
- Company Name: Andex
Re: Tool Measuring Problem
Andrew,
the sensor is probably jamed with dirt. Remove the sponge thats around it, spray some WD-40 in there and press it with your hand couple times to see hove easy it slides up and down. If you feel some restriction, you might have to remove the top of the sensor and cleen the inside with aceton and than spray some lubrican in there. Check on the bottom side if there is a biger chunck of debris rstuck in there.
Nemanja
Nemanja
I have to agree, I had the same problem. It is always a sticky tool measuring switch.
Hey Andrew,
I have the exact problem once in a while. My CNC's are both made in 2002 and one is a C40 and the other is a C42. Both have the same tool length measure device. A milky plastic 2"+- disc on top with 3 small Allen screws. once you remove them there is a spring under it and a plastic sleeve. blow some clean dry air on the metal post and be sure not to loose the tiny screws. Tap it up and down a few times and then reassemble. It works every time for me. I do not use any liquid on it at all. I would ask a Thermwood service tech 1st. If any thing maybe an LPS contact cleaner or similar. Funny thing is that the C40 does it sporadically but the C42 I don't think it has ever done it. I have asked about replacing it with a proximity sensor but they say "been there done that" without good results. So this is a temp fix and maybe 10 minutes of time but it's FREE.
Michael Kowalczyk, GM
