need shower Bases
Gary Puckett
Company Name: The Woodworkery
need shower Bases
Postby Gary Puckett » Wed, Mar 04 2009, 7:45AM
Does anyone know of a site that has shower bases that can be used in eCabinets ?
I am just starting to design a bathroom remodel and the client wants to move the exsisting shower stall to another wall.
Re: need shower Bases
Postby DanEpps » Wed, Mar 04 2009, 8:21AM
There is a tub/shower stall in Sample_HSFs if that would work or you could easily make one from a display cube.
Gary Puckett
Postby Gary Puckett » Wed, Mar 04 2009, 8:27AM
Dan,
Yes it can be made, but it also has to be able to be purchased. Also the cost of the base has to be resonable. I'm sure anything custom would be pricey. The area where the base is going to try to go has a 45 degree short wall in the upper right hand corner.
Postby DanEpps » Wed, Mar 04 2009, 8:39AM
Don't worry about the purchase price for your layout design, just make it to show the customer. There are plenty of options in every price range when it comes to purchasing the actual unit.
You can find a bunch on Home Depot's website to get prices and dimensions. They range from about $265 to $500.
Postby DanEpps » Wed, Mar 04 2009, 8:53AM
Try the Kohler website. They have DXF and DWG files of all their products available for download.
Here is a DXF of just one of their corner showers:
9536.zip
(7.39 KiB) Downloaded 249 times
Gary Puckett
Postby Gary Puckett » Wed, Mar 04 2009, 10:19PM
Dan,
Sorry I missed this post, thanks for the link I think I can make something work from that.
Postby George Davidson » Tue, Mar 10 2009, 7:02PM
Hi Gary
Would you have any sizes on the pan and the walls around the pan
Postby George Davidson » Wed, Mar 11 2009, 11:35PM
Here is one I made about 6 m ago
It is 4 pices drain,floor tile,grout and pan can be changed.
I set it up for 42 x 6 x 42 Pan
I put a 5/8" pitch to the drain (so if you put water into the pan it will run to the center make sure you have a pail with you :lol: )
Bathroom Shower.zip
(125.84 KiB) Downloaded 229 times
Gary Puckett
Postby Gary Puckett » Thu, Mar 12 2009, 10:51AM
Thanks George,
I made one out nof a display cube it turned out ok. This shower pan has to be custom made.
Return to “Customer 3D Files”
