Getting the right light
Gary Puckett
Company Name: The Woodworkery
Postby Gary Puckett » Wed, Mar 11 2009, 8:18AM
Guys,
Need some advise on setting the right light. I know Kerry's says that" Less is More" but there has to be a system in placing the lights. I think all the light fixtures show the same light beam, as for as eCab. goes. This project is driving me :wall: I try a light arrangement and that doesn't work so I try another, and another, Frustration sets in and I close it down and walk away
JohnLashuay
Re: Getting the right light
Postby JohnLashuay » Wed, Mar 11 2009, 10:11AM
Gary,
I have found that using the dome light gives off a very dispersed light. And the high hat light seems to give a more focused light.
I have difficulty with is sometimes as well. Don't give up though!! :wink:
-John
http://www.rylexonline.com
Thermwood CS 43
Postby Kerry Fullington » Wed, Mar 11 2009, 10:51AM
Gary,
Send me the job file and I will light it. If you like the lighting you will then be able to see how it was done.
Save your original file in case you don't like the way I do it.
Michael S Murray
Postby Michael S Murray » Wed, Mar 11 2009, 8:09PM
Kerry,
I am having some troble with renderings and lighting, can I send you a dozen or so jobs and let you do them for me :D :D :D :D
Sorry, its late, I am getting punchy and I want to go home!
Mike Murray
mike@versatilecabinet.com
Gary Puckett
Postby Gary Puckett » Wed, Mar 11 2009, 9:16PM
Michael S Murray wrote:Kerry,
Hey Mike,
You can send me 3 or 4 of those jobs I need the work :joker:
David Tuttle
Company Name: The Kings Woodwright
Postby David Tuttle » Fri, Mar 13 2009, 7:54AM
Kerry Fullington wrote:Gary,
Could I take you up on that I've had trouble making the lighting look right on most projects. My advantage is even a so so lighting is better than what others are presenting.
Postby Kerry Fullington » Fri, Mar 13 2009, 8:21AM
David,
If you want, zip your job file and send it to kerry@kerryfullington.com and I will see what I can do.
Michael S Murray
Postby Michael S Murray » Fri, Mar 13 2009, 9:07AM
Sounds like your working in to a subcontacting business there Kerry...
Mike Murray
