Question about an arch
Moderator: Jason Susnjara
Gary Puckett
Company Name: The Woodworkery
Postby Gary Puckett » Sat, Apr 11 2009, 8:58AM
Does anyone know how to figure out the segments of an arch?
Re: Question about an arch
Postby George Davidson » Sat, Apr 11 2009, 9:55AM
Gary Puckett
Postby Gary Puckett » Sat, Apr 11 2009, 10:57AM
Thanks George,
But what I need is away to figure out the straight line pieces in the arch. I have to tile 3 arches in a bathroom and the trim pieces are 12" long the arch is 30" wide with a 3.5" rise.
Postby George Davidson » Sat, Apr 11 2009, 12:35PM
I would have to see the tiles your using _sizes
Tile 4.441 x 2 in_2.jpg (22.71 KiB) Viewed 4285 times
Tile 4.441 x 2 in.jpg (43.86 KiB) Viewed 4286 times
Gary Puckett
Postby Gary Puckett » Sat, Apr 11 2009, 1:13PM
Thanks George for all the help here is the information. The tile is a trim piece it is 11 13/16" long and 2 1/8" tall
How did you figure it out so I will know how to do it?
Postby George Davidson » Sat, Apr 11 2009, 1:58PM
Try them in CardBoard first
Tile 3.385 x 2.125 in_3.jpg (56.68 KiB) Viewed 4268 times
Postby DanEpps » Sat, Apr 11 2009, 2:25PM
This formula will give you the radius of a circle for known chord length and rise:
R= (((A/2)^2) + (B^2)) / 2B
Where R = radius, A = Chord Length and B = Arc Height
Postby DanEpps » Sat, Apr 11 2009, 2:36PM
If my calculations are correct, it will take 4.85 of those tiles for that arc. You might want to consider much shorter tiles (like 4") to get a smoother arc.
Postby DanEpps » Sat, Apr 11 2009, 2:50PM
Here are a couple of Excel arc calculators.
Arc Calculators.zip
(12.1 KiB) Downloaded 182 times
Gary Puckett
Postby Gary Puckett » Sat, Apr 11 2009, 5:06PM
Thanks Dan and George,
I am creating the arch so I know the rad. the rise , and the cord. What I need to know is how to figure how long the tiles should be to make as smooth an arch as possible. Dan said 4" how did you get to that figure?
Gary Puckett
Postby Gary Puckett » Sat, Apr 11 2009, 5:29PM
Got it, sometimes it takes a while for things to get through this thick skull of mine :wall: . The total lenght of the arch is 32 5/8" divide that by 6 and each piece should be 5 7/16" long now I just have to figure in the grout lines.
Postby DanEpps » Sat, Apr 11 2009, 5:36PM
Gary Puckett wrote:Thanks Dan and George,
Its just a number I tossed out. The smaller the tile, the smoother the curve will be. You method works great when you know the length of the arc and how many segments you want.
Are you going to angle the ends so they will have a uniform grout line or just have a wedge-shaped grout line?
Gary Puckett
Postby Gary Puckett » Sat, Apr 11 2009, 6:18PM
I guess to do it right I have to figure the angle and cut them.
Postby George Davidson » Sat, Apr 11 2009, 7:47PM
Make them on cardBoard
3 Pices of Tile_2.jpg (27.64 KiB) Viewed 4211 times
3 Pices of Tile.jpg (61.27 KiB) Viewed 4212 times
Postby George Davidson » Sat, Apr 11 2009, 8:00PM
Tile cut
3 Pices of Tile_3.jpg (45.82 KiB) Viewed 4201 times
Return to “Lounge”
