Making doors in your shop
Moderator: Jason Susnjara
Postby George Davidson » Wed, Apr 29 2009, 11:06AM
Has anyone made this door in your shop with out a CNC Router
Be for I show the customer I would like to see how hard it would be to make :?:
Test Doors 4-29-09.jpg (74.07 KiB) Viewed 2889 times
Gary Puckett
Company Name: The Woodworkery
Re: Making doors in your shop
Postby Gary Puckett » Wed, Apr 29 2009, 6:14PM
Hi George,
I have never made one ,but you can get a quote from Walzcraft.
Peter Walsh
Postby Peter Walsh » Thu, Apr 30 2009, 10:32AM
George,
The door itself looks like just simple rails and stiles. If the stiles have a flat (not contoured) inner edging where the decorative muntins, etc are going, it shouldn't be too hard to do. The trim should be fairly easy to curve, place and glue at the center joining point. I would build it so that the glass pane is fully rectangular and sits behind the curved trim not into it. You might want to have a flat panel with some non-glue sticking cover (wax paper?) taking the place of the glass during glue up to make sure the trims sits flat when placing and drying.
It would definitely be worthwhile to have a door maker quote on it and if their price fits into your quotation, why not let them do it?
regards,
Will Williamson
Postby Will Williamson » Fri, May 01 2009, 4:16PM
To me it looks like a mdf door with veneer. Should not be that hard to do. Like Peter says use a single piece of glass. Make a templet to pattern route the Archs from the front and then route a rectangle in from the back half way through. Its the kind of Job that make you wish you had a cnc. You would have a half dozen cut within an hour. Another option would be to have a production sharing member make you a set of templets
Will
http://www.willmade.com
Postby George Davidson » Fri, May 01 2009, 4:33PM
That is funny I just started playing with
It will be made with cherry.
I will get back to you in about 2 hour's with my templet if the templet looks good I would like to try to make one Sun.I am make a set of stairs Sat. for Mon. just 12 steps horses,Treads,Risers
Postby George Davidson » Fri, May 01 2009, 8:02PM
So I'm running late :?:
Door 13 x 27.jpg (46.87 KiB) Viewed 2682 times
Postby George Davidson » Fri, May 01 2009, 9:45PM
I all most for got one thing I got 2 rolls in the shop. I hate to use it up at a $1.00 a roll
Wax Paper.jpg (40.04 KiB) Viewed 2665 times
Gary Puckett
Postby Gary Puckett » Fri, May 01 2009, 10:30PM
Really like the forming jig George.
Al dedenus
Country: NEW ZEALAND
Postby Al dedenus » Sat, May 02 2009, 12:09AM
nice looking doors ,better you than me.We made something similar a few months back and two of them took two days to make!!
Postby George Davidson » Sat, May 02 2009, 6:15AM
I thing I am going to use one piece of glass like Peter and Will said :D
Gary I will make a reg hing jig you mind like to have hings up to 3" W
Thank You Gary
Postby George Davidson » Sat, May 02 2009, 11:36AM
That is it for to day
I'm going to a sleep over tonight
My sleep test for the Doc.
I took it from a plan :roll:
I will build it in E-Cab
Hing Jig.jpg (59.88 KiB) Viewed 2616 times
Brian Shannon
Postby Brian Shannon » Fri, May 08 2009, 6:08PM
You've got too much time on your hands, George. Don't you sleep? Cool stuff...
Return to “Lounge”
