Radius Casing question
Moderator: Jason Susnjara
Gary Puckett
Company Name: The Woodworkery
Postby Gary Puckett » Thu, Jun 04 2009, 7:37AM
I need the casing shown below for a job. All I need is two pieces one straight at 5' and another at a 65 degree radius ( width 71 3/8 rise 10 1/2 ) length should be 8' it will be painted.
My question is would it be cost efficiant to use ultra -flex moulding or have someone cut it out on a Thermwood? The size is 1 1/4 thick X 3 3/4 wide MDF is fine. I think Ultra-Flex is about $250.00
Jeremy Schiffer
Re: Radius Casing question
Postby Jeremy Schiffer » Thu, Jun 04 2009, 12:24PM
I would think you should be able to get someone to machine that for less than $250... especially if you did the CAD work and just send the file.
Postby George Davidson » Thu, Jun 04 2009, 6:31PM
Hi Gary try in here for a DXF on it
I think it is under casing
http://www.taguelumber.com/tague/
Gary Puckett
Postby Gary Puckett » Thu, Jun 04 2009, 7:41PM
Thanks George,
I made a DXF of the moulding profile. I tried to post it but the DXF extension is not allowed.
Postby Rick Palechuk » Thu, Jun 04 2009, 9:46PM
You should be able to post it if you Zip it first.
Gary Puckett
Postby Gary Puckett » Thu, Jun 04 2009, 10:23PM
Thanks Rick that worked.
Here is the DXF file of the moulding profile
Casing 4 inch.zip
(4.33 KiB) Downloaded 117 times
Gary Puckett
Postby Gary Puckett » Thu, Jun 04 2009, 10:46PM
Here is a drawing of where the trim is going
Archway Drawing.jpg (27.64 KiB) Viewed 2380 times
Postby DanEpps » Fri, Jun 05 2009, 6:21AM
I think I would go with the flexible molding because if your design is off any at all, you will have an ill-fitting molding.
Postby George Davidson » Fri, Jun 05 2009, 7:14AM
Gary Try this pice
Postby DanEpps » Fri, Jun 05 2009, 8:20AM
Hey George, I see you posted another picture of your wife after you didn't do what she told you to!!! :joker:
Postby George Davidson » Fri, Jun 05 2009, 8:25AM
She is not working now I can use her in the shop now
Jeremy Schiffer
Postby Jeremy Schiffer » Fri, Jun 05 2009, 11:23AM
I think that would cost more than $250 to machine, George. So would the moulding. :joker:
Return to “Lounge”
