Hi
I need a 600mm wide and 720mm high oven and also a 900mm wide and 720mm high oven.
I need a 600 and 900 mm Cooktop also.
Thanks Fred
Under bench Oven
oven and cook top
You can take any of the oven or cooktop files on here and re-size them to suit your needs. I have done it for several projects and it is not perfect but they look pretty good. Kenenth
Re: Under bench Oven
Kenneth,
Do you still have the link to these files. I need a 36" cook top and can't actually find anything on the forum. It's probably here but I can't find it.
Bill
Bill
- Kerry Fullington
Kerry,
Thanks. I can't convert DWG or DXF files to stl/hsf files so I appreciate the format.
Bill
Bill
- Kerry Fullington
Bill,
If you ever need a specific file for use in eCabinets just send me the file or a link to the file and I will convert it for you.
