How to explode
Gary Puckett
Company Name: The Woodworkery
How to explode
Postby Gary Puckett » Sun, May 16 2010, 7:32AM
I have this single wall oven, and I need to explode it to be able to change the texture on some of the parts. I just don't know how to do this. I have proge Cad 2009 smart and I just can't figure it out. I would really like for some one to explain to me on how to do this, it is something I want to learn. Do I explode the whole oven or just the part I want to give a new texture to? Then once it is exploded how do I add layers.
Single wall oven 30 2.zip
(358.76 KiB) Downloaded 248 times
Re: How to explode
Postby George Davidson » Sun, May 16 2010, 4:35PM
Oven 5-16-10
In STL's
You are going to need a new (DOOR) it was no in the box :joker:
STL_wall oven 5-16-10.zip
(153.93 KiB) Downloaded 245 times
Oven Cab Tall 5-16-10_2.jpg (48.91 KiB) Viewed 4416 times
Re: How to explode
Postby George Davidson » Sun, May 16 2010, 4:50PM
O here your parts
Gary Puckett
Re: How to explode
Postby Gary Puckett » Sun, May 16 2010, 5:16PM
George,
THANK YOU!!! THANK YOU!!! THANK YOU!!!
Now I just need to know how in the heck to do it. Do you know anything about Proge Cad smart. I would think the procedure should be the same for all cad programs as for as exploding and doing layers.
Re: How to explode
Postby George Davidson » Sun, May 16 2010, 5:31PM
What comes up when you open export
Gary Puckett
Re: How to explode
Postby Gary Puckett » Sun, May 16 2010, 5:50PM
What do you meen export? Go to proge cad smart 2009 it is free and you will see what I have
Re: How to explode
Postby Kerry Fullington » Mon, Jun 07 2010, 6:44PM
Gary,
I just open the .dwg or .dxf file in Intelicad, select all entities, type explode in the command line and hit enter.
look in the progecad help files for explode.
Gary Puckett
Re: How to explode
Postby Gary Puckett » Tue, Jun 08 2010, 6:18AM
Kerry,
Thanks for the reply but I could explode everything with no problem, I just didn't know how to get the different layers after I exploded it. I finially figured out you just start taking the item apart and start saving the part that is on the screen, then rebuild it and put it all back together. A lot of work.
Re: How to explode
Postby Kerry Fullington » Tue, Jun 08 2010, 6:59AM
Gary,
That is the way it is done and it is a lot of work.
JohnLashuay
Re: How to explode
Postby JohnLashuay » Tue, Jun 08 2010, 11:32AM
How do you guys like your different CAD software? We have a very basic one that we have been using, but it is greatly lacking in the dxf department. I'd like to find out more if you guys would like to share.
-John
http://www.rylexonline.com
Thermwood CS 43
Re: How to explode
Postby Kerry Fullington » Tue, Jun 08 2010, 7:01PM
John,
I have used Intellicad for several years. It is as close as I could get to AutoCad at a price I could justify. If I were buying another CAD program to work with eCabinets I would get Punch ViaCad. I think that is what George Davidson is still using and I have tried the trial versions (several times). For my needs it would be great addition to eCabinets.
Re: How to explode
Postby George Davidson » Wed, Jun 09 2010, 7:53AM
Videos for Punch! ViaCAD Pro v6
http://my.imageshack.us/video/my_videos.php
Videos for.jpg (51.3 KiB) Viewed 4321 times
JohnLashuay
Re: How to explode
Postby JohnLashuay » Wed, Jun 09 2010, 8:48AM
Thanks Kerry & George for the info!
Thermwood CS 43
Return to “Customer 3D Files”
