zip file properties
- Company Name: Scot Acree Woodworkig LLC
zip file properties
What should properties be set to open zip files with?
My setting seem to have been changed and can not remember what I had my zip files set to.
Scot
Scot
Re: zip file properties
"Compressed (zipped) Folders" works with Windows XP.
Dave Egnoski
Richmond Cabinet & Millwork
Right now it says it will open with Adobe under Properties.
What program is this suppose to open with?
Scot
Scot
If you right click the zip folder and select "Open With" you should see "Compressed (zipped) Folders. It's a Windows tool.
Dave Egnoski
Ok , though if I right click on the folder it has the Adobe icon on it.So when I right click on it and go under Properties it says open with: Adobe.
scot
scot
- Curtains.zip
- (39.04 KiB) Downloaded 410 times
When you select Open With it should give you the option to select "Choose Program...". From there you should be able to select what ever program you use for zipped files.
Dave Egnoski
I am going to install a new zip program and start over.
Once I am able to send a zip file again,I am having problems saving a job.
Thanks for the help,
Scot
Scot
Scot,
Right click on your .zip file then choose Extract All
To change it globally, to to your File Explorer (right click on the start button and select Explore)
In file explorer, select the Tools button and Folder Options
A new windows Opens Select the zip file at the bottom of the "Registered File Type" window
Then select change and a new window will open Click OK and close all windows.
Your Zip files should now open correctly with "WinZip" or "Compressed (zipped) Folders" or what ever your choice may be.
Sorry, I couldn't edit my last. I had to redo it to show the images
A new windows Opens
A new windows Opens
