Clipping a TK corner
Brian Timmermans
Company Name: bt.cabinetmaking
Postby Brian Timmermans » Sun, Jan 30 2011, 10:32PM
I have searched and have found nothing.I could use some help when I try to modify a detached toe kick so a corner is clipped I cannot seem to rotate the pieces to cut them on a 45 angle.Is there a way to rotate parts in part editor other than front or back to cut the right section?
Nick M Singer
Re: Clipping a TK corner
Postby Nick M Singer » Sun, Jan 30 2011, 11:58PM
Brian, I assume you are trying to cut a miter on each end of the kick plate? If so then all you need do is apply an appropriate tool to those ends in a profiling operation
Brian Timmermans
Postby Brian Timmermans » Mon, Jan 31 2011, 1:21PM
So do I have to cut my piece to length and then apply the tool to cut the 45 degree? Is there a way to do this in one step?
Scott G Vaal
Postby Scott G Vaal » Mon, Jan 31 2011, 1:28PM
Brian,
Yes, you will have to create each piece to the size needed, then apply a profile edge to one or more edges as desired using a 45 degree tool.
Brian Timmermans
Postby Brian Timmermans » Mon, Jan 31 2011, 6:58PM
Thanks for your help, my head isn't as sore. :wall:
Users browsing this forum: No registered users and 23 guests
