Thermwood / eCabinet Systems • View topic - Irfanview
  • Advertisement
Irfanview
Moderator: Jason Susnjara
Irfanview
Postby Brian Shannon » Thu, Mar 31 2011, 8:10PM
Help! I'm trying to open and convert .DWG files from Sub-Zero/Wolf. Irfanview is telling me that I need to purchase CAD Image DLL to view a clear image. It looks to me that that "Plug-In" is already there. Has anyone had any luck converting these files to .stl? It looks like there has been a problem in the past, converting/openning the AutoCad .dwg files.
Brian
Brian Shannon
Re: Irfanview
Postby George Davidson » Fri, Apr 01 2011, 10:13AM
Hi Brian
I am not sure if this would help you in anyway I use ViaCAD.It workers fine I just convert there new out side grill to STL
Can I help you convert what you need for now tell they work it out in Irfanview
Re: Irfanview
Postby George Davidson » Fri, Apr 01 2011, 1:01PM
Grill for out side
Re: Irfanview
Postby Kerry Fullington » Fri, Apr 01 2011, 5:59PM
Brian,
Irfanview is just an image software. It won't convert Cad files for you. I you talking about Accutrans 3d?
Company Name: Hightech Cabinets
Re: Irfanview
Postby Brian Shannon » Sat, Apr 02 2011, 11:14AM
Sorry for the confusion. Irfanview will only convert image files from one graphics format to another and will not convert to .stl. That is another issue. I just found that it won't open a .dwg file without registering/purchasing CAD image DLL. Here is a .jpg of what I see when I try to open a .dwg.
Here are the appliances that I am attemping to convert from .dwg to .stl. I can open in BobCad and convert to .DXF but can't see anything when I open the ,DXF in Accutrans. Any help would be appreciated.
Thanks!
Brian
BI-48S_S_3D.zip
(3.36 MiB) Downloaded 62 times
427RG_3D.zip
(4.31 MiB) Downloaded 54 times
Brian Shannon
Re: Irfanview
Postby Brian Shannon » Sat, Apr 02 2011, 11:18AM
More files
SO30_3D.zip
(1.52 MiB) Downloaded 56 times
RT36_3D.zip
(3.88 MiB) Downloaded 50 times
MW24_3D.zip
(3.91 MiB) Downloaded 56 times
Brian Shannon
Re: Irfanview
Postby George Davidson » Sat, Apr 02 2011, 1:17PM
Hi Brian
I converted all of your Zip Files put the forum will not let me download it keeps shutting down :fire:
Here are some of Wolf that I have in e-Cabinets right now I just don't have the time to put yours in e-Cabinets today
I am not sure what is going on it will not let me send you any of my Zip Files :wall:
Re: Irfanview
Postby Brian Shannon » Sat, Apr 02 2011, 1:31PM
Thanks so much George! Maybe later, when you have time, it will work. Email may work better if the forum still does not work...
Thanks Again!
Brian
Brian Shannon
Re: Irfanview
Postby George Davidson » Wed, Apr 06 2011, 12:05PM
Wolf App
36 single oven - l series.hsf
(1.05 MiB) Downloaded 60 times
1.hsf
(1.31 MiB) Downloaded 63 times
Re: Irfanview
Postby George Davidson » Wed, Apr 06 2011, 12:07PM
Wolf App2
bi-42sd_s 2000.hsf
(2.42 MiB) Downloaded 64 times
427rg_lh.hsf
(1.25 MiB) Downloaded 65 times
427rg _rh.hsf
(1.24 MiB) Downloaded 65 times
Re: Irfanview
Postby George Davidson » Wed, Apr 06 2011, 12:14PM
Wolf3
48 gas rangetop.hsf
(2.81 MiB) Downloaded 54 times
rt36.hsf
(3.06 MiB) Downloaded 55 times
mw24.hsf
(2.69 MiB) Downloaded 59 times
Re: Irfanview
Postby George Davidson » Wed, Apr 06 2011, 12:17PM
Wolf4
36 dual fuel range.hsf
(3.31 MiB) Downloaded 64 times
30 dual fuel range.hsf
(3.28 MiB) Downloaded 55 times
d_oven for cab.hsf
(598.02 KiB) Downloaded 63 times
Re: Irfanview
Postby George Davidson » Wed, Apr 06 2011, 12:20PM
Wolf5
48 dual fuel range.hsf
(6.91 MiB) Downloaded 65 times
Re: Irfanview
Postby George Davidson » Wed, Apr 06 2011, 12:23PM
Wolf6
15 in electric cooktop.hsf
(176.02 KiB) Downloaded 70 times
30 in electric cooktop.hsf
(190.02 KiB) Downloaded 70 times
36 in unframed electric cooktop.hsf
(230.02 KiB) Downloaded 66 times
Re: Irfanview
Postby Brian Shannon » Wed, Apr 06 2011, 1:59PM
Thanks so much George! I know how much work that was!
Brian
Brian Shannon
Return to Customer 3D Files
Users browsing this forum: Bing [Bot] and 0 guests
