DXF file back operations
Daniel Bell
Company Name: Central City Millworks
Postby Daniel Bell » Tue, Aug 02 2011, 2:49PM
Do back operations from DXF files work the same as other flip ops in control nesting?
Load back side up, 2 (or 3) edge trim, then load front side...
Ryan Hochgesang
Re: DXF file back operations
Postby Ryan Hochgesang » Tue, Aug 02 2011, 3:31PM
Daniel,
Yes, same concept applies. You will need to simply name the Layer name in which the backside operation exist by proceding layer name with word Back. An example of a 1/4" deep dado would be as follows:
back dado z0p25
Scott Marshburn
Postby Scott Marshburn » Wed, Aug 03 2011, 4:32AM
Ryan,
Would that actualy make a 1/4 deep dado or a 1/2 deep dado in 3/4 material? The way I would make a 1/4 deep back dado in 3/4 material is back dado z0p5.
Company Name: Halls Edge Inc
Postby Josh Rayburn » Wed, Aug 03 2011, 6:43AM
That is correct Scott, exactly how you described. Very confusing but it works.
Ryan Hochgesang
Postby Ryan Hochgesang » Wed, Aug 03 2011, 7:42AM
Yes, as Josh has stated, resulting depth would be .5 if material is .75 thick. I appologize for not being clear, I had used a sample part that was .5 thick, which would have resulted in the 1/4" deep dado as I had written it. It does throw a bit of a curve in there that you need to think from top side of material when defining the back operation depth.
Daniel Bell
Postby Daniel Bell » Wed, Aug 03 2011, 1:28PM
Thanks yall, that is a bit funky but I got it.
