can I USE .dwg files in ecabs?
KyleHepp
Post by KyleHepp »
I just nailed down a huge job, and I am hoping to be able to use .dwg files in ecabs to expedite the room layouts. is this possible?
Re: can I USE .dwg files in ecabs?
Sorry Kyle,
You will need to draw them room layouts in eCabinets then populate them with cabinets.
My work around for that is I would trun your DWG or floor plan in to a STL.
Open your custom layout I put one wall in the layout at_0,0 Then put the STL in the layout.
Daniel Odom
Post by Daniel Odom »
George Davidson wrote:My work around for that is I would turn your DWG or floor plan in to a STL.
Cool trick; did anyone ever figure out how to solve the missing lines while printing from LDE? Is there any specific printer/ driver combo that doesn't produce this problem? It would also be nice if drawings from LDE could be exported as dxf files; it would make producing/ editing shop drawings a little easier.
Wally Schneeberger
Post by Wally Schneeberger »
If you have a nice clear screen while in LDE then just do a Print Screen and paste to Irfanview and print it any size or do corrections before printing. You can also change it to B & W or grayscale. FWIW .
