Thermwood / eCabinet Systems • View topic - adding hole pattern to side of draw box
  • Advertisement
Moderator: Jason Susnjara
Postby Jason Stephenson » Mon, Jan 23 2012, 11:26PM
Trying to add some hole pattern to the side of a draw box and running into a bit of a problem, i have made a hole pattern and just cant work out how to get it from the hole pattern folder to the right side of the draw box i could put them in manually but thought you could do it quicker if you made a hole pattern
Jason Stephenson
Company Name: Marks Joinery
Re: adding hole pattern to side of draw box
Postby Josh Rayburn » Tue, Jan 24 2012, 7:48AM
Jason,
Does your hole pattern have a positive depth for the holes being bored into the side of the drawer box and negative depth for the holes in the case side? I have not tried it yet, but I believe this was how it was originally intended to work. I'll have to give it a go today and see if it works.
Company Name: Halls Edge Inc
Postby Kerry Fullington » Tue, Jan 24 2012, 8:20AM
Josh,
That is the way it was intended to work but doesn't yet. Maybe in future versions.
Company Name: Hightech Cabinets
Postby Jason Stephenson » Tue, Jan 24 2012, 3:01PM
thanks for the advise guys put them in the part using part editor and then constraint them
Jason Stephenson
Return to eCabinet Systems Software
Users browsing this forum: Google [Bot] and 0 guests
