Items not showing up in the cabinet buy list
Postby Donald Thomson » Mon, Feb 20 2012, 5:06PM
I suspect I'm doing something wrong but was wondering why hardware items don't show up in the cabinet buy list.
For example, I'm adding a door to a cabinet, I select the drawer pull (Amerock AM-BP5527-BJ) I want for this door. I add the door. Then in the cabinet buy list that pull is not reflected in the list of things needing to be purchased. The same thing seems to happen with my drawer slides. On the flip side, the door hinges and plates and KD/RTA fasteners do show up in the right quantities in the cabinet buy list.
Is there something I need to do to get the other hardware to show up? It is in my hardware list with pricing, distributor, Part#, etc.
Re: Items not showing up in the cabinet buy list
Postby Rick Palechuk » Mon, Feb 20 2012, 7:35PM
Hey Don, I think what's happening is your selecting Drawer Pull instead of Door Pull. When you select Pulls from the Menu, there are two windows, the top one is for Doors, and the bottom one is for Drawers.
Postby Kerry Fullington » Mon, Feb 20 2012, 7:43PM
Don,
After you place the door in the Door Drawer Editor you must select each door one at a time and then click the Add/Locate Pulls button. With amerock pulls there will just be a marker because there are no 3D images but then your pulls will show up in the buy list.
Postby Rick Palechuk » Mon, Feb 20 2012, 7:55PM
Kerry, I believe you can select more than one door or drawer at a time.
Postby Kerry Fullington » Mon, Feb 20 2012, 8:15PM
Rick,
When you place/locate the pulls you must select one at a time because you designate the position of the pull and they are left and right hand doors. If you select more than one door you will get an error message.
Postby Kerry Fullington » Mon, Feb 20 2012, 9:36PM
Don,
Rick was correct, you can select multiple doors to place pulls. :oops:
Thanks for the PM Rick.
Postby Donald Thomson » Thu, Feb 23 2012, 4:15PM
Thank you Rick and Kerry. Your knowledge on eCabs is so very impressive.
Users browsing this forum: No registered users and 32 guests
