Setting Cabinets in a Room
Nicolas Barbeito
Company Name: Zimmerman Furniture Co
Postby Nicolas Barbeito » Thu, Nov 01 2012, 1:16PM
When I go to set a cabinet (any cabinet) in a room I get this trail following behind.
What would cause this to happen? Also the cabinets do not snap to the wall or each other as you can see in the picture.
It did it before and it still does it with the latest version.
I run Windows 7 Home Premium
My laptop is a HP Pavilion dv7 Intel i7 2860qm @2.5 ghz, 12gigs of ram, and a 2gig video card.
Thanks!
*Edit- And yes I have updated all drivers via windows update.
Company Name: Halls Edge Inc
Re: Setting Cabinets in a Room
Postby Josh Rayburn » Thu, Nov 01 2012, 1:27PM
Nick,
Try updating the video card driver and see if that helps.
Also you can select "align to back" as the placement method which should snap the back of the cabinet / assembly to the wall.
Hope this helps,
Nicolas Barbeito
Postby Nicolas Barbeito » Thu, Nov 01 2012, 1:41PM
My system is less than a year old, has a good video card, I have windows check for updates daily, and I have manually attempted to upgrade my card (it says it is already running the best version).
The video driver is not the problem as near as I can tell.
Scott G Vaal
Postby Scott G Vaal » Thu, Nov 01 2012, 1:47PM
Nicolas Barbeito wrote:My system is less than a year old, has a good video card, I have windows check for updates daily, and I have manually attempted to upgrade my card (it says it is already running the best version).
You MUST update your graphics driver by downloading the latest from the video card manufacture's website and then installing it. Doing it via the Windows Operating System will not care about OpenGL drivers and that is important to eCabinet Systems. Please update the driver in this manner and see if the issue goes away.
Nicolas Barbeito
Postby Nicolas Barbeito » Thu, Nov 01 2012, 2:29PM
No Scott, that does not help either. Radeon say to get it from hp, so I downloaded the update from hp and it still runs that way.
But the placement issues were fixed. I must have for some reason checked freestyle and never turned it back to wall. Thanks, Josh.
Scott G Vaal
Postby Scott G Vaal » Thu, Nov 01 2012, 2:36PM
Nicolas,
What is the model number of your Radeon card?
FredHirsch
Postby FredHirsch » Thu, Nov 01 2012, 3:10PM
Nicolas,
See if changing your color depth fixes. I have a machine that does this and finally just changed color depth and everything OK. I think I went from 32bit to 16bit in driver software.
Fred
Fred Hirsch
Postby Kerry Fullington » Fri, Nov 02 2012, 4:44AM
Nicolas,
Try adjusting your Hardware Acceleration. This has helped with this problem in the past.
