Does anyone know if it's possible to get rid of the narrow center back portion of the corner cabs? I have an unusual bifold corner application that needs to have that 'center back' removed so that there is a 90 degree corner.
Tim
Corner cabinet solution
Re: Corner cabinet solution
Tim,
In construction settings, click the corner settings tab, and change the corner gap to 0.
http://screencast.com/t/mmTvIOFswP7
Hi Tim.
Try this.
Theres a section in the construction settings when you have a corner unit selected
construction settings.
Corner settings
Corner Gap.
Hope this helps.
Try this.
Corner settings
Corner Gap.
Hope this helps.
Awesome, Thanks guys. Thought there was a spot for that setting. Stared at he construction settings all morning and it was right there in plain sight!
Thanks again,
Tim
Thanks again,
Tim
