Bar with Glass Shelves
That's it now I can go to bed
- Company Name: Custom Trim and Millwork
Hi Audrey
I learned it from Kerry
Make a Display cube the size of your shelf then do the texture match as Jody said. You can then copy and paste the rest of the shelves. If you want the material to show up on cutlists, create a sheet stock called glass then make your shelves as display panels from this material. You still have to do the texture match once the shelves are in the cabinet. Don't forget to associate the display panels or cubes to your cabinet before you save.
Audrey,
Ton experience va au-dela du dictionaire.
Quand j'ai demenage a Calgary il y a 24 ans, j'avais l'anglais du dictionaire et c'etait pas aussi bon que ton anglais.
Bonne Chance et Joyeux Noel.
Jean-Gabriel Voyer
Janot Interiors Ltd
www.customcabinetscalgary.com
Janot Interiors Ltd
