Is there a way to estimate cut time for a job?
JohnLashuay
Postby JohnLashuay » Fri, Jan 17 2014, 9:28AM
Does anyone know if there is a way to estimate how long it will take to cut a job? I have a customer who have a large number of duplicate small pieces and I would like to be able to figure how long the whole job will take to cut so I can plan our production schedule.
Any ideas?
Thanks! ...John
http://www.rylexonline.com
Thermwood CS 43
Company Name: Halls Edge Inc
Re: Is there a way to estimate cut time for a job?
Postby Josh Rayburn » Fri, Jan 17 2014, 10:57AM
John,
I'm sure it's not as quick as you'd like, but you could always program one sheet and run it in the air to get an exact time. If there were enough of them, that's what I'd do to be sure.
Daniel Odom
Postby Daniel Odom » Fri, Jan 17 2014, 11:04AM
There is a program called cut-timer available on the cnc automation site that works for non-3d parts and sheets of parts created in control nesting. I tried the demo and it seemed to be reasonably accurate. It lets you adjust parameters to match your setup as well. Most cam programs have basic time estimation but it can be way off depending on your machines acceleration/deceleration rates and tool change times.
JohnLashuay
Postby JohnLashuay » Fri, Jan 17 2014, 5:20PM
Thanks guys for the responses!
Thermwood CS 43
Will Williamson
Postby Will Williamson » Thu, Jan 23 2014, 1:58PM
Aspire will do that. Based on the feeds and speeds then you can adjust to your particular machine.
Will
http://www.willmade.com
