drawer stretcher
Ron Sloan
Company Name: Wine Country Custom Carving
drawer stretcher
Postby Ron Sloan » Thu, Apr 10 2014, 10:27AM
Is there any way to add a drawer stretcher that I can actually use to set a partition to? Doesn't seem to recognize the stretcher in the partition editor...
Scott Marshburn
Re: drawer stretcher
Postby Scott Marshburn » Thu, Apr 10 2014, 11:16AM
Use a Fixed shelf.Adjust the insets to get the width you need.
Ron Sloan
Postby Ron Sloan » Thu, Apr 10 2014, 6:07PM
Thanks for the quick reply Scott!
I figured it out after posting.
One more question. If I want to notch the partition for the stretcher, how do I do that? I can't seem to figure it out. i.e. I want the top of the partition to be flush with the top of the stretcher.
Ron
Scott Marshburn
Postby Scott Marshburn » Fri, Apr 11 2014, 5:27AM
Hi Ron. When you insert the partition set the top offset to the thickness of the fixed shelf make this a negative value i.e.. -3/4. Then return to main. Select the partition and take it to the part editor. Here you can make a pocket cut for the fixed shelf. I would then take the partition to the constraints manager and constrain the cut so it will keep the notch when the cabinet is resized.
Ron Sloan
Postby Ron Sloan » Fri, Apr 11 2014, 9:59AM
Perfect - Thanks, Scott!
Users browsing this forum: No registered users and 8 guests
