Hi Nat.
The drawer box hole pattern will not transfer to the ends of the second cabinet because the drawer is in first cabinet or vice versa. You can however get the hole pattern by taking the left end of the cabinet that has the hole pattern for example into the part editor and creating edges. Select the front edge and offset it by 14 15/16 in this case. Now you need to mirror the hole pattern. Select the holes that you wish to mirror then click on the mirror tool and select line. This should mirror the hole pattern. Now you need to select these new holes and create a pocket at the depth that you wish. From here you can take the part into constraint manager and tweak them as needed.
Cabinet With 2 Faces
Re: Cabinet With 2 Faces
Looks great, thanks very much Scott.
Nat Wheatley wrote:Looks great, thanks very much Scott.
Thank you Nat. Please keep me informed on how this works.
- Company Name: Zimmerman Furniture Co
posted in wrong topic sorry
plz delete
plz delete
Users browsing this forum: No registered users and 15 guests
