Hi, it seems everytime now i goto the part editor to profile panels, it seems to crash on me
Its when i go to do the second profile edge, it comes up with the error saying ecabinets has stopped working grr. Ive done this many times and its only just started coming up with this message and crashes the program.
Help!?
I am running the up to date version of ecabinets also. Version 6.0 Build 15
Crashing
- Company Name: Not Just Kitchens LTD
- Country: NEW ZEALAND
- Company Name: Thermwood
Re: Crashing
Have you updated your video card drivers? You could post the error from the event viewer, that may if a little more info on the problem. Start ecabinets, do the steps to make it crash then hit ok to the error. Then get the error from the event viewer. The easiest way to do this is to select Start, then Run. Type eventvwr.msc and press ENTER. Under Windows Logs, select Application, and then find the 'X' that details the problem.
You should be able to highlight the text in this window and then press <ctrl><C> to copy the text. Paste this into your post for review.
Rick Deskins
eCabinet Systems Programmer
