angled shelves
- Company Name: Classic Custom Wood
angled shelves
Ok I can get a fixed shelf to follow the angle on an angle cab but not the adjustable. Is this right or am I missing something?
I can take the adj. sheves in PE but hey I'm lazy!!!
Re: angled shelves
Ray,
There is a selection for Adjustable shelves in the Angle Part.
Re: angled shelves
I'm home now and I can't even get the fixed shelf to give me the option. Both fixed and adjustable are greyed out. Both in the main section and also in the shelf editor part.
Re: angled shelves
Ray,
You must place a Fixed Shelf or an Adjustable shelf in the cabinet first and then the options in Angle cabinet will work.
Re: angled shelves
Thanks Kerry, I was figuring that since the setting is on the Add shelf tab that the setting had to be established before the shelf was added. Got it now.
Re: angled shelves
I know I am resurrecting the dead here but I have a problem with the shelf also.
Mine is a bit different. I can have my deck to follow the angled side but not the shelf. No matter what I do the fixed shelf stays square. I have tried highlighting it before applying the setting, no highlights, shelf in, shelf out (off course this becomes greyed out). No matter what, I can not get the shelf to follow the side.
Also, do I have to set the face frame and door as as display parts?
Re: angled shelves
This is crazy. I lost the deck angle and now I can't put it back. It stays square. I really need help with this. I know I must be doing something wrong. I can't imagine this is so difficult, I must be thick.
Re: angled shelves
I can't believe no one has any take on this. Why is this happening and how can I circumvent this problem? I really need to make a cabinet to work in that way.
I guess I can always use the part editor but it is just guess at best for almost all parts.
Re: angled shelves
Here is what I am trying to do but the opposite way. This one was done with the part editor but I am sure it would be easier to do it with the proper tools from the program.
- Clipped Corner.jpg (13.73 KiB) Viewed 12061 times
- Clipped Corner.hsf
- (356.02 KiB) Downloaded 443 times
Re: angled shelves
Hi Denis.
You should be able to accomplish this using an angled front corner cabinet. And a second cabinet with everything removed except for the face frame.
Re: angled shelves
Well that sounds interesting. Not quite what I want to achieve, I would like the two doors to open together as in a Lazy Suzan cabinet door but I will give that a go and see if I can pull it off.
Thanks Scott
Thanks Scott
