Assembly???
Calvin Williams
Company Name: Williams Woodshop
Assembly???
Postby Calvin Williams » Wed, Jul 15 2015, 10:26PM
I built an assembly connecting the range hood cabinet to the cabinets on each side as this is the way we typically build it in the shop. Now I am having problems placing it on the wall. It won't let me place the assembly where I need it. Anyone had this problem before? It is probably something simple that I'm not aware of being new to eCabinets. Thanks!!
Scott Marshburn
Re: Assembly???
Postby Scott Marshburn » Thu, Jul 16 2015, 3:03AM
Hi Calvin.
When placing assemblies in the room they are setting on the floor. If you need the assembly to be for example 48 inches from the left of the wall and the bottom 53 inches from the floor. Place the assembly on the wall that you need it on. Then go into elevation view. Click on the assembly and move your mouse all the way to the left of your screen. The position on wall dialog will pop up. Here you can adjust the distance from the left to 48 inches and the distance to the bottom to 53 inches.
Hope this helps.
Calvin Williams
Re: Assembly???
Postby Calvin Williams » Thu, Jul 16 2015, 3:47PM
Hey Scott,
Yeah, that's what I do and it will not move for some reason. :wall: :wall:
Scott G Vaal
Re: Assembly???
Postby Scott G Vaal » Thu, Jul 16 2015, 4:18PM
Calvin,
You may have to change your Place Mode to Free Style to get it to move.
Calvin Williams
Re: Assembly???
Postby Calvin Williams » Thu, Jul 16 2015, 10:24PM
That worked.... Thanks a lot!!!
Users browsing this forum: No registered users and 49 guests
