pocket screws
john jurkowski
Company Name: mcmanus development
pocket screws
Post by john jurkowski »
hey guys, I am in search of the proper way to add pocket screws in ecab to a display panel I have created. any info would me much appreciated thank you
Scott G Vaal
Re: pocket screws
Post by Scott G Vaal »
John,
You cannot add pocket screw construction to a display panel. Only cabinet parts will allow a construction method to be added.
Now, with that said, you can take a cabinet and remove all parts but the back and use it as a display panel and get the construction added. I will attach a cabinet that I have applied the pocket screws to all 4 sides of a back for you to uses or review. You can re-size it to whatever dimensions you need and turn off the construction on the joints that you do not wish to have pocket screw applied to. Hope this helps.
Pocket Screws On a Back Only.jpg (9.65 KiB) Viewed 31914 times
Pocket Screws On a Back Only.hsf
(338.02 KiB) Downloaded 2067 times
tim lucas
Re: pocket screws
Post by tim lucas »
Scott,
Can the Shopbot link cut the pockets for the pocket screws?
www.TLCW.us
Scott G Vaal
Re: pocket screws
Tim,
Sorry, the link does not support pocket screw machining.
tim lucas
Re: pocket screws
Post by tim lucas »
Thanks Scott, maybe someday :D
www.TLCW.us
Scott G Vaal
Re: pocket screws
tim lucas wrote:Thanks Scott, maybe someday :D
Tim,
I will certainly add it to the wish list for you.
tim lucas
Re: pocket screws
Post by tim lucas »
Tim,
Awesome!
Thanks again
www.TLCW.us
Re: pocket screws
Post by Forrest Chapman »
Tim, until then you can make a RTA hole pattern that is just a slot and apply it. It will cut it as a dado.
tim lucas
Re: pocket screws
Post by tim lucas »
Forrest Chapman wrote:Tim, until then you can make a RTA hole pattern that is just a slot and apply it. It will cut it as a dado.
I will have to give that a try
Tim
www.TLCW.us
