New HD issues
Marcel Thibodeau
Company Name: Northwest Kitchen Centre
New HD issues
Postby Marcel Thibodeau » Wed, Oct 07 2015, 11:18AM
After having some mysterious problems with the HD on my CS43 I ended up having it ghosted and replaced with a SSD, very happy with the solid state, nesting is much faster.
Somewhere along the line with all the testing of the old and new drives my CPU clock somehow reset and has thrown off my maitence schdule, basically it thinks I am -111000 hrs past due. Doing an item reset doesn't work, it just crashes the supercontrol. is there a file i can delete to fix this.
Another issue is that the machine won't physically boot, even though I have set up the correct boot sequence every time I shut the machine down I have to take the side panel off and hit the button on the mother board to start it up. As a result I just set it up to go into sleep mode when not in use. Not entirely sure if this will be good in the long run but i don;t see how it could seriously effect anything
Any thoughts?
Gerry A Brown
Company Name: Old Style Woodwork
Re: New HD issues
Postby Gerry A Brown » Sat, Oct 10 2015, 2:12PM
Hi Marcell,
You might want to check if the windows partition is marked as active. Sometime when restoring a drive clone the partition is not flagged properly.
