V6.1 Crashing
Nat Wheatley
V6.1 Crashing
Postby Nat Wheatley » Wed, Dec 16 2015, 5:37PM
I've had the program crash a fair amount of times recently. It's happened on a number of different projects, and I'm not clear on what's causing it. It seems to happen at random times and I can't put a finger on what the instances have in common. Today I added some constraints to a cabinet, and believe it crashed going back the CE and may have crashed again going back to the batch.
Using Win7 SP1
Leo Graywacz
Re: V6.1 Crashing
Postby Leo Graywacz » Mon, Jan 04 2016, 9:57PM
Did you apply the hotfix?
Dell Precision 7710
NVIDIA Quadro M3000M
256 GB PCIe NVMe - M.2 SSD
Win 7 Pro 64-bit
http://lrgwood.com
Nat Wheatley
Re: V6.1 Crashing
Postby Nat Wheatley » Tue, Jan 05 2016, 6:07AM
Hi,
Didn't think it was for this version of Windows, but will try it. Thanks
Re: V6.1 Crashing
Postby Kerry Fullington » Tue, Jan 05 2016, 7:22AM
Nat,
As always, make sure your graphic card drivers are the latest and greatest.
Nat Wheatley
Re: V6.1 Crashing
Postby Nat Wheatley » Tue, Jan 05 2016, 7:33AM
Thanks Kerry, will upgrade the graphics card drivers as I haven't done that in a while.
Clint Hart
Company Name: Foxwoods
Re: V6.1 Crashing
Postby Clint Hart » Wed, Jan 20 2016, 2:49PM
I am having the same problem, it crashes every time I try to print any Nested Layouts depending on the number of items on the list it seems. It will work if I put like 10 of one item but if I go to 11, and try to print, it just crashes...getting rather aggravating. Seems it can only handle a very limited amount of info...I am still on XP unfortunately, I have to run other programs that aren't supported, so I'm kind of stuck with this OS. It also happens on the Windows 7 system we have here, I've tried 4 diff computers, same result.
the hotfix for the appropriate OS has been run on each of the pc's also.
Any suggestions?
Users browsing this forum: Google [Bot] and 14 guests
