Install window or cut opening then install window?
Carmen Addamo
Postby Carmen Addamo » Sat, Dec 19 2015, 1:36PM
What are the differences between just installing a window/door on a wall as opposed to cutting an opening first then installing those items
Scott Marshburn
Re: Install window or cut opening then install window?
Postby Scott Marshburn » Sat, Dec 19 2015, 2:36PM
Hi carmen.
It is mainly presentation. The first screen shot shows 3 windows. All with no cut outs. The third window has an image applied to it. You can use custom images of your own.
The second screen shot is with cut outs along with some lights. Notice the lights behind the wall and how they shine through as well as the lights in front of the wall. This was just a quick example but with some practice you can create a very impressive presentation this way. Doors can be done the same way. You can make the opening then have the door open to allow light to pass through.
Postby Kerry Fullington » Sun, Dec 20 2015, 2:00PM
Carmen,
Something else you might want to try. I created some upper cabinets styled to look like windows. You can be as detailed as you want. The reason was that once I placed the window I can then place a sink base underneath it and use the Re-size/equalize feature to center the sink perfectly under that window. You can also re-size these windows after they have been placed in the room. They are created using "Do Not Cut" materials to keep them off the cut list.
Carmen Addamo
Postby Carmen Addamo » Sun, Dec 20 2015, 2:08PM
Guys Thank you both for the explanations and ideas.
