Floating "No Video Input" on power up
Steven Jacobs
Company Name: Carl Jacobs Chair Company
Postby Steven Jacobs » Sat, Mar 05 2016, 12:02PM
Hi all, I posted this on the 5-axis side but not much action there , so I thought I would re-post my cummunication issue over here and see what I get.
I am getting a floating "No Video Input" on power up. This Model 70 5-axis double ended spindle machine has a GEN-2 Super-Control console installed in a complete retro fit in the end of 2006.
I have removed the controller’s low voltage side panel and observed that the mother board appeared to not power up. This conclusion was from seeing processor fan not rotating and only 1 small red LED lit just over it adjacent to a 4 pin connector. I powered down and disconnected this 4 pin connector (I assume a power switch) and repowered (120vac only) and the motherboard did powered up. But still had a floating "No Video Input".
Is this a bad power supply, a switching issue, a bad video card or something else?
Thanks in advance for any input or suggestions,
Steve J.
Will Williamson
Re: Floating "No Video Input" on power up
Postby Will Williamson » Sun, Mar 06 2016, 10:06AM
Open up the cabinet and plug a known good monitor in and see if it works. Call thermwood tech support they will diagnose the problem in just a few minutes. 1 800 221 3865
Will
http://www.willmade.com
Marius Gouws
Company Name: Plett Roofing
Country: SOUTH AFRICA
Postby Marius Gouws » Wed, Mar 09 2016, 1:41AM
If you have a on board video card then swap the motherboard out just to see if it work, if you PCI graphics card then swap that out. Seems to me you have faulty motherboard.
Steven Jacobs
Postby Steven Jacobs » Thu, Mar 10 2016, 4:03PM
Yes call the support (dud) should have so from the start. Great help and Fast.
Battery was shot once replaced I needed to hit the reset button on the mother board
Up and running thanks :beer:
Users browsing this forum: Tommy Wieler and 8 guests
