Radius Compensation
Kim Dang
Company Name: Mart Design
Radius Compensation
Postby Kim Dang » Sat, Mar 26 2016, 9:30AM
Hi all,
I have 58 letters nested on 1 sheet.When I nested the job, no errors or warnings appeared. The nesting was fine, but the cut. When it cut for a bout 20 minutes, the machine stopped and the window said " while radius compensation is one, a line to arc intercept calculation failed" I tried to re-nested and re-cut the job. Same thing happened at the same place. I searched for solutions from the forum. I reduced .001" from the tool diameter and re-cut the job. Same error appeared. I tried and tried 5 times on the same sheet until midnight. Tired of waiting 20 mins before the machine stops each time I try to recut. Could you plz tell me if I can start the job where it stopped before?
Look forwards to your reply
Re: Radius Compensation
Postby Forrest Chapman » Sat, Mar 26 2016, 12:36PM
You may be able to move a few lines down and start from there. It might be that it leaves a little geometry to clean up by hand but that is better than not getting the job done. Can you post the file you are trying to cut?
Postby Kerry Fullington » Mon, Mar 28 2016, 12:33PM
I had a similar problem once and mine was caused by a curved part that tapered to absolutely nothing. I had to take my file into Contour in the Part Editor and did a small (.0625) filet so the part didn't go to nothing. This allowed the machine to think it could make the turn.
Look at your drawing where the machine stops and see what your parts look like.
Company Name: Halls Edge Inc
Postby Josh Rayburn » Wed, Mar 30 2016, 6:28AM
I get that all the time. I just find the J or I coordinate that is a 0 and change it to anything other than 0 and it works great.
Also, once you start the file and complete the first tool change, you can navigate to another tool change, or if you already have the tool you want, then you can navigate anywhere in the code and press start. You will probably get a confirmation "are you sure you want to start here?" just say yes and you're back where you left off.
Hope this helps,
Dave Burtchell
Postby Dave Burtchell » Fri, Apr 01 2016, 1:31PM
We've had this problem for years. In our case, it stems from the fact that our cad software, Rhino, outputs the dxf file in 8 decimal places, while Thermwood only reads 4. The fourth decimal place is either rounded up or down depending on Rhino's 5th decimal. So, when we get the "line to arc intercept" error, we look at the g-code line that's highlighted, and the next line down. That second line of code usually has either an "x", or "y" value that is .0001" higher or Lower than the highlighted line. Let's say the highlighted line is y23.1234 and the next line is y23.1235, or y23.1233. We hit "tab" and change the first line to match the second line and continue on. Works for us every time now. We used to agonize over a workaround, or redraw the part, or skip ahead and forget the bad part. Try it, you'll like it. Let us know if the explanation isn't clear.
Users browsing this forum: No registered users and 0 guests
